On startup of Rhino I’m getting the error “Object reference not set to an instance of an object”
Unsure what to do, it seems like its also not letting me log in to the “team” to grab the licence either.
Cheers
Cheers
Hi!
Having the same issue here.
Do you have a solution yet?
greetings
If you only want to use the team licence you need to remove your personal licence.
It should then hopefully work as this worked for me!
Yes! That worked!
Many thanks!
