I used Sweep2 in Grasshopper. After the operation was completed, I found that there were large gaps between the surfaces. After switching to Loft, there were also relatively large gaps. Has anyone encountered the same problem? How did you solve it?
The first picture is the preview effect of the surface generated by Sweep2 operation, and the second picture is the lines used for sweeping
looks like the rails and the shapes are not mapped correcly.
is it possible that there is some shift - meaning the rails of the next section are used…
if you need more help - you need to post your file
EDIT:
my screenshot-guess:
you use the wrong combination of rails and shapes like this:
the red curves are used for the sweep2
Thank you soooo much, I’ll try it later
