Hi @Holo, can you provide the ifc file please? you can send it to visualarq@asuni.com
That way we can figure out what’s happening.
Yes sir,
sent you a mail, please check to see if the link works, if not I’ll send it via wetransfer.
Hi @Holo, we have fixed this issue in VisualARQ 2.9 version. VisualARQ 2 - Version 2.9 released (for Rhino 5, 6 and 7)
That’s only halfway there Francesc, but still no cigar…
And make sure you track the errors internally so you can report that it fails. I can only imagine the frustration for your users when they discover that VisualArq skips important building information without letting anybody know.
THIS IS REALLY IMPORTANT!!!
Hi @Holo that’s strange, I got a little better-imported model but still see some gaps and windows whose material is wrong… But I see we don’t have exactly the same model. Please send me that new one, and we will dig a bit further.
Thanks, new file on the way.
And PLEASE inform them on the need for a bug list + add a TextDot with an exclamation mark (!) on the places where it fails. Reporting bugs is even more important than getting everything right IMO, but it needs to get everything right to be reliable of course.
Thanks! I’ve got the new file, and everything looks quite correct.
Are you using VisualARQ 2.9? (Make sure you have the public version: http://www.visualarq.com/download/update/)
What Rhino version do you have?
Strange… I just upgraded to the latest this morgning and I have Rhino 6sr 30.
The file was imported to another file, could the local tolerance f*** things up?
(We always use I meters and I have it at 0.001. (1mm) )
If so I guess you should add a custom tolerance to make sure IFC has a good enough tolerance.
As we HAVE to be able to import IFC’s into other files and still TRUST that what we get is the correct data. I can not stress enough how crucial this is
Cheers
Finally getting some results for you:
I just tried opening the IFC in Rhino and let VisualArq set it’s own settings (mm and 0.01 as tolerance) and then it gets the windows right.
I also tried changing my tolerance:
0.0001 meter fails
0.00001 meters (equals to 0.01 mm as you have) also fails.
But setting it to mm and 0.01 WORKS!
Go figure! What’s the difference between 0.01 mm and 0.00001 meters?
So we are getting closer to the issue here.
I’ll update my template, but please do everything you can to make it robust so importing it into existing files works just as well.
Setting it to 0.001 mm gets some of the internal windows holes right too:
As you can see in your image the two lover left windows are not punched through:
One of these got fixed by uppint the tolerance to 0.001 (But only one)
I don’t know, but this might be linked to Rhino’s age old coplanar-face-boolean crappyness
Yeah, we are getting closer! thanks for these details.
How is that you had the tolerance to 1mm?
The model you sent me has the Absolute tolerance to 0,01mm.
How were you opening the IFC file before? dragging the file into Rhino viewport? Through Import command? Through Insert? Just Opening it?
In any case, I think the model should look right with a 1mm tolerance. We don’t recommend using a smaller one, since the calculations become far more complex and this affects modeling performance. In architectural projects, it doesn’t make sense to have more accurate precision.
Hi, I usually drag it in and use import if the file is small and I need it’s content.
On large files like this I make a new file based on my template (Which has a much more sane render meshing setting than yours to be frank, at least for my needs) and then I import the IFC by dragging it in.
And this is what I do with it after that:
I have a script that mesh the objects (since extract render mesh uses a different meshing engine that is overly complex too) and then I join all meshes based on render color.
That way I get a super light and responsive model that I can snap to and use this as an xref in the actual project with out hogging all resources.
This workflow works very well for my needs (when the model works that is… )
