… instead of changed frame count.
-Micha
-Micha
I’m sorry, I’m not following. Which piece of the UI is causing the issue?
Hi @Joshua_Kennedy,
I used _BongRenderAnimation.
Here I changed the fps from 25 to 15 and the length jumped from 50s to 83.3s. I would like to keep the length and get less frames.
Good luck,
Micha
The Render Dialog in general needs to be updated. It’s been logged here. I think what’s happening here is the Render Dialog is trying to keep the other settings in sync when changed, and making some assumptions which may not be correct.
