the fields to enter values are grayed out
Untitled.3dm (149.8 KB)
Why would you like to enter a value? Are you maybe trying to use Active Connections?
You’ll need to enter animation mode. Keyframes are set for the grayed out values the same as those on the timeline for position and rotation.
but on the video you’re not in that mode
Well, that video was made prior to change that allowed keyframes to be set. Before that the values were constants. We’re still in a WIP
Well, then, if the Animate button is activating the Animation Mode and change values, what button should I use to actually start the animation?
Also, why every time I select a connection its type changes to “custom”?
Untitled1.3dm (3.1 MB)
Got it…
