I get this error in Rhino 9 WIP. The component goes red a few seconds after placing it on the canvas. Can you please take a look?
Also another issue: the toolbar in Rhino 9 WIP is missing the Meshing components at the left:
@DanielPiker can you please take a look?
An error occured during GHA assembly loading:
Path: C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\Isopod\1.0.4.1\Isopod.gha
Exception System.IO.FileNotFoundException:
Message: Die Datei oder Assembly "System.Drawing.Common, Version=8.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
@martinsiegrist I think you might be running Rhino 9 WIP in .NET Framework (4.8) mode, and Isopod is only compiled for .NET 7. If you use SetDotNetRuntime
, you should be able to switch it back to .NET Core mode which should get this working again. If you’ve modified your shortcut to add /netfx as an argument you’ll have to remove that.
It might be worth it to get Isopod multi-targeted so it can run in either framework.
