Hi, i trying to use V-ray and met the situation when i need to isolate object to ajust material, but isolating affects light too.
Is there any soluthions to avoid that, and isolate only geometry without lighting?
Thank you!
I thought probably there is a isolation filtre or something, do not lock lights individually
You can place your lights on a hidden layer and enable “hidden lights” at the switches options of V-Ray.
