Windows 10.0.19044 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 11-26-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 497.09
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-26-2021
Driver Version: 30.0.14.9709
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\XNurbs (80be33b0-13b2-4ac4-9c77-03829214f9e9)\5.2.0.0\XNurbsRhino7.rhp “XNurbs”
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Users\Charles\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.4\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.4.0
C:\Users\Charles\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\raytraced-blend-material\1.5.0\RaytracedBlendMaterial.rhp “RaytracedBlendMaterial” 1.5.0.0
C:\Users\Charles\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\raytraced-materials\0.1.5+v7.4\RaytracedMaterials.rhp “Raytraced Materials” 0.1.5.0
I’m not seeing here either with the provided file…
@Charles Please make sure you can duplicate the problem with the exact file you posted here. I know that might sound strange, but sometimes users will get something to happen, then save their file to some “test” file and send it off…thinking that the file they just saved will show the problem…but never really verifying that they can reproduce the problem with said file… So, please download and test your own file to see if it happens.
Also, by “semi transparent”, do you mean Ghosted display mode? If so, is your Ghosted mode at its default settings, or have you made any tweaks? If you’ve tweaked settings, then please export your display mode(s) that show this problem and post them here.
It looks like this might be a near/far clipping plane issue based on when/where the isos turn off and on… Unmaximize the view, and with the view still active, run ShowCamera… This will display a crude wireframe of the camera’s frustum in all views. Now try to repeat the problem and take note of any changes to the camera icon (in the other views) when the isos turn off and on.
Doesn’t sound strange, it is a highly important point.
I already did so before starting the topic.
I’ on a German Rhino right now, I didn’t remember the correct term.
I think Ghosted is right.
Oh, I wasn’t aware of a non-standard setting, sorry.
The altered setting is exactly about isocurves.
Perhaps this is the root of the problem.
I should replace vanish by appear in the topic title… Halbtransparent.ini (13.3 KB)
Bingo! The “Show isocurves” setting in Ghosted mode is what’s causing this. I guess I should have noticed they were turned off in the non-selected state… Selected objects are apparently showing all isos and edges in certain cases but not others. Note: It appears all modes will behave like this if/when isos are turned off.
I guess the question I now have… What should the behavior be? If you’ve intentionally turned off isos, do you expect them to turn on when selecting an object? Or should the display remain the same, and the object is now just “highlighted” ?
@pascal Ok, that’s what I would have expected as well…
Can you YT this, using this thread and example as reason for why this should be… Fixing it will automatically fix Charles’ issue…stick it on my list.
Hi Charles, I am not seeing that here so far - if I understand, you want isos not to be shown except on selection (?) and then not drop out on view rotation, correct? (current behavior here) or do you not want isos to show at all on selection if the display mode is not showing them? Either way would make sense, I see that in your example it is neither one nor the other…
