Can someone briefly explain to me the use of the RhinoCommon member CommitChanges()? I’m specifically interested in how this function works with materials and textures. My basic problem is I want to edit a material applied to a brep object and see those changes reflected in the document. Right now I’m basically doing the following:
selection=rs.GetObject(“select surface”)
obj=rs.coercerhinoobject(selection)
material=obj.GetMaterial(True)
tex=material.GetBitmapTexture()
tex.FileName=rs.OpenFileName(“Choose Image”)
I can see that when I create a reference to the material/texture object and subsequently edit one of its fields, that the IsDocumentControlled property goes from being true to false; I guess this means the RhinoDoc is no longer reading changes to this object. So I call CommitChanges() on this object to tell Rhino that I’ve made changes and expect to see them reflected in the doc. However, this command seems to fail every time. Should i instead be constructing a new object of this type (e.g. Texture), editing it, and applying it back to the object in question (or making a new RhinoObject?). Or is the editing in place way ok?
What is the proper way to think about accessing/editing the lower level info of a general RhinoObject?
CommitChanges just takes the object that you have modified and pushes these changes into the document. I don’t see CommitChanges in the script that you posted so I’m assuming that there must be a little more to the script.
@stevebaer- that was my basic understanding, and i assumed it was not necessary to use CommitChanges() all the way back up the object hierarchy: i.e. if i’ve changed the material, i would call commitchanges() on the it, but would not need to call commitchanges() on the docobject referencing the material. here’s the full code:
import Rhino as rh
import scriptcontext as sc
selection=rs.GetObject("select surface")
tex.FileName=rs.OpenFileName("Choose Image")
material.SetBitmapTexture(tex)
print material.CommitChanges()
print obj.CommitChanges()
sc.doc.Views.Redraw()
Unfortunately, there is some weird stuff happening when i use this.
The material.commitchanges() always returns true, but the obj.commitchanges() always returns false. is this behavior to be expected?
The script only changes the rendered texture the first time I use it on a document. subsequent uses do not change the appearance of the surface.
When the script works, the rendered texture changes to the image i selected, but if i go into the object properties and look at Textures, often the “Color” field will still show the filename of the old image, not the new one. Also, if i run Unwrap on the new texture, it will revert back to the texture that was on the surface prior to running the script. I assume these are related issues.
What is the index of the material? If it’s -1, its the default material, which you cannot modify. You might have to create a new material and assign it to the object…
