Is vertical tufting in subd easy?
Hi all,
I am trying to model this headboard with subd but couldn’t find a fast way for vertical tufting.
I am playing with subd but couldn’t find a better soluiton like 3dsmax has.
In 3dsmax ( I believe in Blender can do it the same way.. )
*first I added some vertical lines.
*select the lines and give Extrude as shown in image.
*turbosmooth :slight_smile:
In Rhino I think I have to add lets say 3 vertical lines on the right but I have to add double vertical lines for each line so I can scale the middle ones in invard to make it look like tufting.
So in 3dsmax I need 3 lines but in subd I need 3+2+2+2=9 lines.
you need 3 edges to make a corner-
see this video
so, you will need 3 edges to bend inward, 3edges to bend the bottom of the tuft, 3 more edges to bend back up, and 3edges to bend back to the starting surfaces.
