Is there any option or short process?please help?
I generally use the gumball for quick edits like this. Click the Gumball’s white menu ball, turn on Snappy Dragging, and Align to Object:
Ok thanks.but is there any python script to do it instantly?
_Extend will take a boundary object and automatically connect it if it intersects. You can also extend ToPoint and manually pick the points.
And you can make a script to do this. Instead of manually picking a point, you could find the nearest point on your boundary curve to each endpoint. Then you can either extend or move the endpoint to that point.
I am not smart enough to create a script,sir?if you help me it will be my pleasure sir?
Is there any python script to do it?
Is is possible?it will help many users
