So I build historic sailing ships in Rhino to use with tabletop games… I have one with a serious problem i’d love to get some advice on.
The subject is HMS Ontario and the goal is to create a 3D printable file. I initially had a serious issue getting the bulkhead rail to union to the hull. I finally got it to go only to find out the bulkhead if a bit too thin to print properly.
I wanted to extrude a thicker rail and union it back on, when i discovered seemingly nothing would union to my model at all any longer. After much colorfull langauge and trial and error i found my problem. The union of the rail had created a set of naked edges on the inside of the bulkhed where it joins the hull, thus creating a hole.
I can’t seem to patch this… i’ve tried creating a surface from the edge curves but there are more then 4 edges and one of the edge lines is literally split in the middle. I’ve tried patching it with the join edges, no dice… In short I’m out of ideas how to patch this…
I wouldn’t think about it like trying to patch the hole, but rather repairing the trim. I would extractSrf the surfaces with naked edges, untrim them, and intersect / trim so they match.
You could try duplicate edge the join the curves then sweep2
or you can duplicate all edges join them up,
make a point somewhere and do loft to make a surface, though it probably won’t be so clean…
