Is this a bug?
Rhino can’t calculate “Area” for this simple polyline.
Is this a bug or something else?
unable to calc area.3dm (53.0 KB) ?
Looks like it… very odd. Can you describe how you made it? I tried a bunch of the “usual suspects” and nothing worked to fix your object. If I trace a simple rectangle over it, that calculates.
Ah, it’s not 100% planar - if you use ProjectToCPlane, it will then work correctly.
Although _PlanarSrf Succeeds, so Rhino thinks in some cases this Polyline is planar :thinking:
Of…course…duhh!!
Although I extract it from a “planar” surface from witch area could be taken.
Well…guess that has something to do with tolerances and stuff
Sorry…jumped to soon on this one :stuck_out_tongue:
Yep, this is typical, depending on who wrote the command, the tolerance is different. Area probably uses the TryGetPlane() method without a tolerance argument, which defaults to 1e-12 tolerance…
The same method also accepts an optional tolerance as overload.
I filed a bug report…
https://mcneel.myjetbrains.com/youtrack/issue/RH-54319
