Is there way to set different axis scale in Layout?
Hello All,
I wish to setup my layout model such only the Y-axis is magnified, while keeping the unit intact.
Is there a way to do this?
There’s a horizontal and vertical view scale settings under Document Properties/View/Display Mode/xxxxx/Other Settings. When changing the vertical view scale, unfortunately, it affects both the model and layout space. More interestingly, it also stretches the paper size. There’s no separate magnification setting for only Y-axis.
Thank you for reading.
George
Hi George -
That is not possible, no. You’ll have to either 1D scale a copy of the original geometry or use Make2D and 1D scale the resulting curves.
