Is there any way to wrap the whole objects on a free form surface by using sporph or something?
Hİ all,
I am new at rhino and I need to make a space frame on a free form surface . Making a space frame is pretty easy with structure 1 . However I don’t want to divide surface in 2 directions. I want to make equal length space frame along the surface. like 3x3 .
So firstly I tried project command for top level of space frame . But project command deformes the line length.
Secondly I used flow along srf command. But I couldn’t keep the objects all together on the target surface as following image.
Thirdly I used sporph command and turned on the rigidity. But again my frames are not welded. They are seperated again.
Is there any idea how I produce space frame which parameters by frame length not divisions. Finally I will adjust the frames at the edges of surface.
Thanks in advanced.
Elif
A grid of equal edge length quadrilaterals on a surface is called a Chebyshev net.
Finding such a net on a freeform surface will generally require some iterative solving process.
Here’s one example of how this can be done in Grasshopper:
Thank you very much for your quick reply Daniel Piker .
I download and viewed drape_sphere.gh . Following picture make sence about your gh? because while I try to open it, I got some warnings about version.
And I couldn’t find any surface set option, length input button
setting mesh is not valid.
Maybe this can be very likely all because my inexperience.
Thanks in advance again
