Is there any way to make surface with control points?
I’m having trouble creating a surface with these control points. Could you suggest a method or component?
this is a group of control points.
I appreciate about your attention.
Thank you again!
Hi 고인혁 -
If you need to create a surface from unorganized points or curves, you’d typically use the Patch component. For terrains, though, I’d recommend making a mesh with the Delaunay Mesh component.
thank you for your considerable reply! It really helped me a lot! Thank you again. And hope you to have wonderful next year!
