I can array it and then trim it one by one. I’m seeking a way to do so in an easier way like what SOLIDWORKS does.
1.3dm (169.4 KB)
There are a few ways to attack this that might save a few clicks, but Rhino is not “feature-based” so you can’t array a feature like your rib and have it automatically trim the base surface.
Either array the feature and then use Split to split the main surface with the feature copies - but you still have to delete the unwanted srfs, or
Array the feature, take the first one CCW, split the base surface with that, that will give you a small trapezoidal “pie section” of the cone. Then select that and the original feature, delete the rest, array the feature plus the pie section and Join.
(as per Cyver’s illustration)
–Mitch
