Is there an upper limit of the dimensions of array?
I got the following error when trying to duplicate a list with 4161 elements 116,508 times: Solution exception: Array dimensions exceeded supported range.
May I ask what’s the upper limit of this array dimensions? and How to solve such issue?
Could you explain the context of what it is you’re trying to do?
I’d guess that there’s a more efficient way to break it up or make use of paths.
