I like to model with a light grey background, but when I take screen shots to drop into powerpoint I need the background to be white so the image will look nice on the slide.
Is there an easy way toggle back and forth between background colors? There doesn’t appear to be a way to save appearance settings.
Options>View>Display Mode. Select one of the display modes like for instance shaded. Click copy, then rename it (Maybe like "Shaded White Background), change the background color setting there to white. Click OK. Now you can switch to that display mode when you need the white background.
