I have a simple mesh box with the tops and bottoms removed. I would like to control the top 4 vertices to lift the upper corners of the box independently. Right now, the only way I can manage to set it up is to manually select the appropriate vertices, and plug each one into move component, and then rebuild the mesh after that.
I would like to know if there is an easier, more efficient way to go about this. I’m trying to get better at modifying meshes within Grasshopper.
2021.02.25_McNeel_forum_01.gh (16.8 KB)
