Is there a way to turn off this shadow?
I’ve circled in the photograph the shadow I’m trying to remove. I turned it off before although I cant find the setting anywhere. I thought it was Ambient Occlusion although this on/off does nothing.
is this a rendering or a technical view?
if it’s a rendering, turn off skylight
if it’s technical view, shut off the shadows in the display settings.
Its a Vray rendering. GI (Skylight) is already off.
Is it a dirt material for AO effect? What kind of setup do we see?
If you don’t want shadow effects than you could use a white emissive material and outlines.
I have Ambient occlusion turned off for the whole scene in the settings tab. Is there a way to turn it off on the material?
It would be easier if you would answer the questions? What kind of setup do you use? Why not emissive materials?
I didn’t know that V-Ray has an AO option. I’m not sure what kind of setup you use.
