Hi, I just wanted to ask. I just used OffsetSrf to add a little inner and outer thickness to a model, and I can’t see inside it. How do I know how much that was actually added? There must be a way to take a measurement
Mathias
Mathias
Can you try wireframe and length by point to perp. Or could you draw a line through all , then split curve by surfaces and measure result?
Hi, I actually used ghosted view and just zoomed in all the way to the wall of the model and took a measurement. It worked
