Hi all,
I need to create startup script that sets units and tolerances to new values and it needs to work in v4. Any hope?
Thanks,
-Marc
Hi all,
Thanks,
-Marc
You could just create a template file with all the setting you want or need. Then just have Rhino use that template file when it starts.
Tools -> Options -> Files
No script needed…
This is easy to make, but as Dale says, if you need it AT startup, then it makes more sense to make a template.
If you still need a Script then let us know what values you need.
Yes, I know that and all users are using the same template already.
But I need a way when opening and importing documents too.
Opening a document will set the file units correctly if the document being opened has units attached. Otherwise, open a template with the desired units and use Import, not Open.
–Mitch
Hi Mitch,
I’m well aware of that but it doesn’t help.
I have a lot of users and want to cover every possibilities.
@Holo; the values are:
Units: Inches
Abolute tolerance: 0.00004 units
Relative tolerance: 0.1 percent
Angle tolerance: 0.1 degrees
I know these values are not at all optimal for any logical purpose. It’s a compromise I have to make in a world with 20 000 engineers around me.
I know too that any geometry made before the tolerance is changed will stay as it is and may not behave when modifying / editing etc.
Hi Marc,
The following should do what you want… You can modify the coded-in values to suit if you need.
HTH, --Mitch
SetFileUnitsTolerances.rvb (729 Bytes)
Thanks Mitch, that’s perfect!
