Is there a way to save GH Mesh Settings?
For 3D printing I have to export baked GH geometry as an STL file. I made something that looks bad when baked/exported from either GH Breps or Breps converted to Meshes that use the standard settings. But I found that by updating the Mesh settings I could get a much finer Rhino result that resulted in a good STL file.
I’d like to be able to save my updated Mesh settings so I don’t have to load my current GH file and copy/paste its updated Mesh object into every new GH project. But I don’t see a way to do this. Am I missing something, or is it just not possible?
Set the mesh settings to what you like, Then select the component and go to File>Create User Object. Fill out the info required and then you will have now a component set to those settings.
Absolutely spectacular! Got it - did it. Many thanks.
