Hey all, I’ve drawn a series of sections that I’d like to transition into each other. As you can see, I’ve extruded the sections and stacked them against each other — ideally this wouldn’t be the solution, ideally they would connect more smoothly. The forms are meant to be organic. Is there a way to adjust an extrusion’s form after making it? Or is there a better way to go about this? I didn’t have much success lofting the sections together. In another attempt, I was able to (sort of) loft the voids together, but then unable to subtract the voids out of a larger geometry.
Thanks for the help! Much appreciated.
