Hi everyone,
I tried to disassemble the combination,
but it still cannot be combined into a closed object
I can’t figure out what went wrong,if you know.please
Please tell me if you know the reason, thanks.
combine.3dm (3.6 MB)Hi everyone,
combine.3dm (3.6 MB)When I only select some components, they can be combined.
But multiple selections will not work.
If you know the reason, please tell me, thanks
Actually I couldn’t get your problem properly. Try Brep Join component.
Cheers,
BVR
HI ajarindia,
I have tried it, but as I mentioned above, when I choose to merge all, the result is failed.
It’s more the problem of drawing percision and geometry rather than method for joining them.Here I had to change a bit the geometry to make it eligible for boolean union operation.
Boolean Union.3dm (1.5 MB)
