Is there a way to change the array along curve to be like rhino 6?
i just installed rhino 7 everything was fine until i used array along curve command. My feeling about the new command is pretty bad as it’s not as intuitive as it is in rhino 6. is there a way to still use rhino 7 but change the command to look like rhino 6?
Hi Chicken -
That is not possible, no.
This was changed because the old dialog box in Rhino 6 and before didn’t offer any preview. In Rhino 7, you can change all the settings in the command line and get real-time feedback in the viewport. You can read more about the background involving the change in item RH-6445.
