Im looking for a way to stack multiple objects in rhino.
I created a 3d model then used sectiontools to split that model into 0.2 mm sections, ive created these sections so they can be laser cut but i need to check the model stacks properlly, if that makes sense.
Ive got 295 models that are 0.2mm thick that need to sit on top of each other in order. I can do it one by one useing the move command but its a very time consuming process and im wondering if theres a comand i can run to automate this process.
Thanks
Luke
