Hello.
Is there a way change _new document’s name (filename) and file path without saving it, so _save would suggest desired filename and directory?
Thank you.
Hello.
Thank you.
By saving it for the first time using the “Save As" command and typing in the desired filename? Then every time the “Save” command is issued it will save to the specified file.
