Is there a RhinoCommon equivalent to Rhino's "What" command?
I’m looking for a way to return the number of vertices in a closed polysurface. Using the What command displays the information I need, but I need to be able to work with the results in a script. Any suggestions?
The only information I need is highlighted above.
Thanks,
Dan
Once you have a polysurface (Brep), you would walk through each face in the brep using the Faces property. For each face, call GetMesh and if a mesh exists call mesh.Vertices.Count
Thanks Steve. I’ll give that a try.
Hi @DanBayn,
This might also be useful:
import Rhino
def test_what():
    filter = Rhino.DocObjects.ObjectType.Surface | Rhino.DocObjects.ObjectType.PolysrfFilter
    rc, objref = Rhino.Input.RhinoGet.GetOneObject("Select surface or polysurface", False, filter)
    if rc == Rhino.Commands.Result.Success:
        rhobj = objref.Object()
        if rhobj:
            log = Rhino.FileIO.TextLog()
            rhobj.Description(log)
            print(log.ToString())
if __name__ == "__main__":
    test_what()
– Dale
Thanks Dale.
