Is there a reason why Blur is doing nothing?
blur mesh internalized.gh (1.9 MB)
I want to blur those pixels but nothing works :frowning:
Hi @ShynnSup,
Hmm, what is creating the mesh upstream? Some kind of solar study plugin?
I thought it was the mesh geometry itself at first but when I feed a Z value gradient into the mesh colors it is smooth as expected:
I suspect it’s something about the way the vertex colors are being handled but I also am just guessing
Yes it was done with ladybug, but vertext colors are vertex colors in the end, that’s what I don’t get.
I tried to triangulate the mesh, trimesh it, and rebuild it and that didn’t work either.
I tested on a mesh cube and blue mesh worked fine so the component itself is not bugged out.
It does look like the topo is a quad mesh and, while quads except blurring, I wonder if it doesn’t like that quad mesh. What was the mesh result prior to the quads? Or was it always quads?
Thanks for helping me out.
It was a delauny mesh, then I quadremeshed it. But Blur worked fine with that same mesh and other vertex colors before… mmm, I don’t think it’s the mesh :frowning:
I think you need to run blur mesh prior to Quad remesh.
Did you quad remesh before or after the ladybug component that generates the radiance map?
I would blur the triangulated mesh post ladybug, then quad remesh the blurred result
I noticed that all internal edges are unwelded. Once welded, blur works fine.
blur mesh welded.gh (1.9 MB)
My guess is that the issue is the following: Ladybug is assigning one value per sensor(meshface), thus one colour per face.The colour of meshes is normally assigned to the vertices (3 or 4 (repeating)colours per face). When welded, the colours are assigned correctly to the vertices and we know the neihgouring colour and can average it(mapping the colour to a value and averaging it).
:wink:
The mesh just isn’t welded.
So you know the makers of ladybug decided to not weld the mesh, Just because they can?
I tried to find a explanation for the reason. I did understand, that the mesh, which is outputed is not welded.
Sorry but that wasn’t clear from reading the post above.
No need to be sorry Martin. Sorry for not expression myself better.
Ahhh, thank you!!
