Is there a point edit command for joined surfaces like this?
I use Solid point and point to edit a lot. I thought I could do the same with surfaces like this. I’s like to pull the one with the red dot over without affecting any other dimensions. What command?
Just window select the solid edit points and drag…?
You can also subobject select the six end surfaces and drag those.
Moved to Rhino for windows
As @Helvetosaur says, you can hold Ctrl+Shift and drag a window to select all those vertices, edges and faces and then move altogether.
