Is there a function of c++ sdk that has the same effect as RhinoApp().OnIdle(1)+=OnIdle() of c# sdk?
Hi;
In c# when I run this code:
public class MyPlugin: Rhino.PlugIns.PlugIn
    public MyPlugin()
        Instance = this;
        RhinoApp.Idle += OnIdle;
    private void OnIdle(object sender, EventArgs e)
        RhinoApp.Idle -= OnIdle;
        DoSomething();
    public static MyPlugin Instance
        get;
        private set;
    public override PlugInLoadTime LoadTime
        get { return PlugInLoadTime.AtStartup;}
    DoSomething()
          //to do what I want
Rhino will run the function DoSomething() after Rhino open, now I want to change my code to c++,
but I can not find function whicth same effect as this code, which friend can help me?
There is sample in the Rhino developer samples on GitHub.
cmdSampleIdleProcessor.cpp
– Dale
Hi @ dale:
Get it, think you.
In the sample, I must run the “_SampleIdleProcessor” command, but I want run it when rhino startup.
I means I just want to run some function, turn the event on v…v at rhino startup, in c# it easy to implement, I just need set “RhinoApp.Idle += OnIdle”, and add the “public override PlugInLoadTime LoadTime” function, now I need the same effect in c++.
CRhinoPlugIn::plugin_load_time CMyPlugIn::PlugInLoadTime()
	return CRhinoPlugIn::load_plugin_at_startup;
I have found add the function above cant load plugin at rhino startup,but rhino still print nothing when I do like:
int myfunction(int x, int y)
	int z = x + y;
	return z;
BOOL CJewellyForRhinoPlugIn::OnLoadPlugIn()
	int z = myfunction(1, 2);
	RhinoApp().Print(L"%d\n",z);
	return CRhinoUtilityPlugIn::OnLoadPlugIn();
Can you give me some sample to solve it?
Just curious, why would you want to switch to c++?
@stevebaer
Protect code from decompiling :grinning:
Hi @suc_kiet,
Based on the sample that I referenced, add the following to your plug-in’s OnLoad overide:
BOOL CSamplePlugIn::OnLoadPlugIn()
  // TODO: Add plug-in initialization code here.
  theSampleIdleEventWatcher.Register();
  theSampleIdleEventWatcher.Enable(true);
  return TRUE;
– Dale
