I want to remove those tiny fillets. manually exploding and cleaning takes lot of time. especially if you have large no of such curves in geometric patterns. so can anyone suggest me some better way to do that
For 2D curves, _Offset (inward per your example) with Corner=Sharp at a Distance larger than the radius of the shapes to remove, then _Offset the result back toward the original curve.
yes i like the trick, thanks for your reply, i think along with this , offset multiple command can do the work.
Voila it work like charm, you just have to play with distance carefully.
Fillet curves with value 0 ![]()
yes but that dont work for patterns having thousands of curves with 6-7 sides each. actually we used to do that in autocad.
