Is there a component in grasshopper that does the same thing as the rhino 'Text' command
I want to write text with grasshopper into rhino construction plane as actual text.
The rhino ‘Text’ command gives you a number of useful options like the ‘justification’, and the fact that it is actual text, among other things.
Is there a component in grasshopper which does the same thing as the rhino command where text has an option for its justification and can be baked as actual text.
Thanks.
Check Text Tag 3D(Display–>Dimensions–>Text Tag 3D)
I knew there had to be something.
Thank you
