Is there a better way to get this?
I want to simulate the carving with a chisel. So I wrote this below. But I think there must be a better way to get it. Thanks!
#Create a function for carving with rectangle.
def trianglecarving():
#Create a sketch curve on a surf.
    commandsketch = "_Sketch"
    curve = rs.Command(commandsketch, False)
    if not curve: return
    new_curve01 = rs.LastCreatedObjects(select=True)
#Create a triangle surrounding the curve.
    #Creat the plane for the rectangle
    if new_curve01:
        plane = rs.CurvePerpFrame(new_curve01[0], 0)
    #Creat the triangle
        rectangle01 = rs.AddRectangle( plane, 3.0, 0.5)
        if rectangle01:
            #Mirror the rectangle and then create the rectangle
            plane1 = rs.ViewCPlane()
            xform = rs.XformMirror(plane1.Origin, plane1.Normal)
            rectangle02 = rs.TransformObjects(rectangle01, xform, True )
        if rectangle02:
            explodedCurves = rs.ExplodeCurves([rectangle02], True)
            curve0 = rs.FirstObject()
            curve1 = rs.NextObject(curve0)
            curve2 = rs.NextObject(curve1)
            curve3 = rs.NextObject(curve2)
            pointstart = rs.CurveStartPoint(curve3)
            pointend = rs.CurveEndPoint(curve3)
            point01 = rs.AddPoint(pointstart)
            point02 = rs.AddPoint(pointend)
            midpoint = rs.CurveMidPoint(curve1)
            point03 = rs.AddPoint(midpoint)
            trianglepolyline = rs.AddPolyline([point01,point02,point03,point01])
            if trianglepolyline:
              surface = rs.AddPlanarSrf(trianglepolyline)
              #Extrude the triangle prism
              triangleprism = rs.ExtrudeSurface(surface, new_curve01)
            if triangleprism:
                rs.DeleteObjects([rectangle01,trianglepolyline,new_curve01,surface,curve0,curve1,curve2,curve3,point01,point02,point03])
            #Boolean the box
            input0 = rs.LastObject()
            input1 = rs.FirstObject()
            rs.BooleanDifference(input0, input1)
if( __name__ == "__main__" ):
    #Call the function
    trianglecarving()
trianglecarving-L3W1.py (2.0 KB)
