Is the GetLocalTangentPoint method buggy?
Sometimes the GetLocalTangentPoint method identifies only one tangent spot on a curve when there are more than one tangent. Increasing the seedParmameter does not help. Why is the method not locating the second tangent point? "What can be a solid alternative for identifying tangent points besides this method?
GetTangentPoint.gh (7.6 KB)
… i had similar problems with GetLocalTangentPoint
splitting the curve and evaluating the smaller curves / sections should help.
looks like a geometric problem of the curve.
if you rebuild the curve, or fitCrv or _removeMuliKnot…
the tangent-point is found
(EDIT)
splitting is not nescessary…
splitting does not help.
your script works as soon as you rework the curve.
find attached version including splitting…
GetTangentPoint_02.gh (11.9 KB)
Much obliged! Yes, rebuilding of the curve has solved the problem! Perhaps the problem with edit point density
