I want to be able to set the user text or the material properties and also have the normal properties visible. right now i have to keep switching between them
Hello - nope, those are all stuck where they are. Can you describe what it is you’re trying to see or get at with both of the panels?
typically i want to be able to adjust the layer, object name, object color as well as view/edit user text without having to switch tabs.
Hi Pascal, it would be awesome to have a tab for Named Objects and a tab for Named Groups,
Like what we have but instead of a pop up menu a tab on the side, similar to the named views, named cplanes, etc we could have a named objects and named groups one.
Cheers
