Is multithreaded performance better in Rhino 7?
I’m curious if anything was done to take better advantage of multithreaded CPU in Rhino 7.
I know 3d modeling is mostly single core because things have to happen in a particular order, but in scenarios where you’re processing a complex boolean or filleting hundreds of edges, is that a situation where you could use several cored to divide and conquer the calculations? Or did Rhino 6 already work that way?
not many commands in rhino are multi threaded, however in v7, rhino can now run on a machine with more than 63 cores (previous limits) for the processes where multithreading is useful.
we have a dev using a new threadripper and v7 is running well-
