Is it possible to turn off unused file extensions for file export
I’m using Rhino 8
I typically use either .step , dxf or stl when I export a drawing or object.
Is it possible to temporarily turn off the rest of the file extension options in the list so that I don’t have to page through the list each time?
When I say temporary I mean that I would still like the option of turning them all back on if the need came some point down the road.
Thanks,
Kent
Hi Kent - all of these are handled by plug-ins. In V8, if you disable the file IO plug-ins in Options > Plug-ins page, and restart Rhino, the disabled ones should not appear.
Thank You Pascal,
That did the trick…
Just a follow up question, is it possible to also turn of the older rhino export options from the list?
For example its still giving me the option to export to Rhino ver 3, ver 4
Thanks again…
Kent
Hi Kent, as far as I know this is not possible.
