Is it possible to set different line weights for layouts on Mac?
Ive seen it be done on windows but on my Mac I don’t have the column ‘Layout print width’ …? Does the Mac version just not have this ability?
Cheers
Hi Phil -
That column might have become unchecked somehow?
Hi Wim, that looks like rhino8… do you know how to pull up that check list on r7?
thanks
Hi Phil -
Sorry, I didn’t notice the tag.
That check list is not available on Rhino 7, but the column should be there:
I did find the check list… but no option to tick for layout line width…
a screen shot taken from a you tube tutorial… see the two columns, one to adjust model print width and the other to adjust the print width independently in the layout
Hi Phil -
Yes, on macOS before Rhino 8, there were two completely different layer panels: one for model space and one for paper space.
On Windows and in Rhino 8 for both platforms, there’s a single layer panel.
Ahhh ok yes I see, thank you Wim!!
It can be easy to get snagged on these little differences between windows and Mac sometimes … good now that both versions look the same in rhino 8, smart move.
rhino is the best!
