Is it possible to orient gumball to the aspects of dim or NU?
    Christian Carey
F.I.T
Hi Christian - it is not clear to me what you are asking here…
In other words orientation of gumball in adjusting directional relation of the conveyed direction closed crv seam like an auto-snap for GUmballl
Hi Christian, Do you mean, you’d like the gumball to orient to the curve seam and tangent direction?
Lasso NU point may open you to the congruence of direction. With an adjust the closed seam to reposition gumball properly or not if you rock your c-plan with tangency or prefer history enable with the function dubbing the direction by adjusting the accordance of the Crv seam to manipulate the gumball for extrusion based on the adjust Crv seam just to have a snap to snap to position sub-D organically.
Is there a way to sequence gumball to the dim of that object and alternate with congruency of nu to alternate in the sequenced N and U interlaced pattern or the interlacing of NU . AS to sequence a Celtic knot with an scroll. Thru grasshopper can that be dubbed nu with a corresponding regional direction to be labeled with numbers to thus ease to shot and ladders of scroll work.
