As the tittle suggests, I need to model an airfoil moving in time in order to use it for fluid dynmaics analysis, is it possible to do so using openNURBS?
thank you a lot
thank you a lot
Are you using Rhino or just the openNURBS toolkit?
You can certainly model airfoils in Rhino, and the data (e.g. curves and surfaces) are represented in openNURBS.
As far a real time, this isn’t anything either will do without some custom programming.
Have you seen Grasshopper? This is a great tool for doing generative, real-time design. there may be fluid dynamics addon for Grasshopper available.
Well, the fourthD is TIME. That suggests to me to try Bongo.
