Is it possible to hide only part of a mesh?
Hi there,
I am using the mesh2surface plugin to generate nurbs from a mesh surface. There are some inaccessible areas on the mesh that would be easy to get to if I hid half of the mesh. Is this possible?
All suggestions and help gratefully received.
Mike Logan
You could unweld and then explode the mesh to split it into its face and then select and hide areas. This could be very slow if the mesh is dense. Alternatively, clipping plane?
Hi Mike - you can turn on points for a mesh, select some points and HidePt Or, you can try CullControlPolygon to hide back facing mesh faces. Or, possibly ClippingPlane may help.
