Is it possible to copy and paste an image into Rhino 6?
We use the Picture command frequently, but that involves saving the image to a file first, then using the Picture command. Is there a way to just copy and paste an image without the need to save the image first?
What I would like to do is capture an image with SnagIt, and paste it directly into Rhino. Like this:
Thanks,
Dan
Not currently. The command-line will tell you:
Command: _Paste Unable to paste, no Rhino objects or text on the clipboard.
This has been requested before: https://mcneel.myjetbrains.com/youtrack/issue/RH-40450
I’ve added the link to your request here to the item.
Thanks Nathan. That would save so much time if it was possible.
Yeah, second that… --Mitch
I’m working now on the drag&drop code that works with clipboards as well. Maybe one could have a look sooner than the distant future.
That’s great to hear Nathan. Mitch pointed me to this thread because I asked for the exact same thing for the same use case that Dan posted: Screen captures from Snagit.
My request was here, as part of another request of dealing with embedding images: Is there a way to check if all Picture Frame images that were imported are embedded in a file?
RH-40450 is fixed in the latest WIP
Thanks for adding this.
