Is it OK to loosen tolerance to get booleans to succeed?
In the attached file, I have set the tolerance to 0.01. When I do this, I can boolean union the pieces into a closed polysurface in Rhino 7 and Rhino 8 (does not work in Rhino 6).
I plan on making a video showing various ways to make a model watertight so that it can be printed.
I intend on showing shrinkwrap in Rhino8, of course, and the art of “nudging” for Rhino 6 and 7, as well as importing into Blender to remesh-and-export-stl.
I don’t know why, but on a whim I decided to try loosening the tolerance to see if it would also work and, unexpectedly, it did.
Is it “bad” to loosen the tolerance like that in a small-objects-millimeters file? Are there problems to keep in mind with this approach? If it is “bad”, would it be “okay” if we first saved to a different file so that the original file keeps the 0.001 tolerance?
16 ring done v6.3dm (17.1 MB)
Depends on the use-case. There is no need for 10^{-10} mm precision, if your machine you manufacture with can only handle 10^{-2} mm precision.
Hello @webdunce
The ring is very well modeled, cool stuff! My suggestion here is that, generally, tweaking tolerances by these small amounts is not truly a problem - Dan answered with a great understanding of the difference in scale.
I also have another comment. In this particular case where the result is a mesh to print, simply using the mesher + the new mesh Booleans in Rhino 9 BETA may be best: both faster and more precise. I used the _Mesh command with “Smooth and Slower” settings, then _MeshBooleanUnion. The result is closed and pretty good geometry.
This is thanks to the new mesh booleans in Rhino 9 BETA.
Just using the polysurfaces directly with mesh boolean union (no mesh command) gives an open mesh. I traced this back to 28 of the 34 input render meshes -from Rhino 5?- each having 3 naked edges: one triangle short per prong. This can be fixed also after-the-Boolean with _AlignVertices and _MatchMeshEdge.
If you use Grasshopper, Sasquatch has some “Fast Boolean” tools that allow tolerances mid-stream, so you don’t have to change tolerances in Rhino Preferences.
all polysurfaces have this red cylinder:
_ShrinkTrimmedSrf (will work on the polysurfaces also)
then _booleanUnion is working fine here.
(Rhino 8, Mac os x)
in this case its a good practices to clean up final geometry:
replaced with a single cylinder / surface:
16 ring done v6_UnionByTomP_rh8.3dm (13.4 MB)
i would not teach / document to juggle with tolerances.
there are many cases where it is ok-ish, but for other data-chains its a huge source of errors. - my 2 cents
EDIT:
rule of thumb: document tolerance is 1/10 of smallest detail.
in your case there are details with 0.02 and 0.06 mm.
0.001 is the correct choice for the document tolerance
happy modelling - kind regads - tom
