Is it be possible for DWG Export plugin to write Linked blocks as xrefs?
It would be great if blocks (or worksession files) that are linked into the 3dm Rhino file that is being saved as a DWG or DXF file were interpreted as “xrefs” (AutoCAD’s external references) pointing to the original file location rather than being embedded as a new block in the written autocad file. Is it something that ODA converter can do?
This is the same question I have with a job I’m on now. Any thoughts or movement on this specific workflow?
