Is Blend command obsolete?
In Rhino 6.11 Blend command does not autocomplete and it is not listed in the menus. Is Blend command obsolete?
You can use BlendCrv instead: Blend vs BlendCrv
Menu: Curve>Blend Curves>Adjustable Curve Blend
Andrew
I knew that.
Hi Andrew - Do you miss it??
No. The fewer total number of Rhino commands, the better.
