Does anyone know if its possible to make a text box that constrains the area in which text goes and auto returns when it reaches the limits of the box? hope this makes sense.
This would be super useful if possible. Currently the text just keeps going off the layout page.
@john11 - can you tell me , is there anything that youād be able to do that you cannot do now, with the proposed text box? The thing is such a tool as an option on Text would make for a messy workflow so chances are it would be a new command if implemented - in writing that up for the devs and decision makers, it would be helpful to be able to point to a solid need or advantageā¦and as I think about it, it seems like you can get what you need currently - what would be the advantage of setting up the box ahead of time? And what happens to overflow?
When you manually insert text, then all is fine as it is now.
When you use text fields, however, it can become very tedious catching overflow after the boxes have been populated. This will be the case in many fields in a āTitle Blockā, for instance.
(and then there is still the bug where, when shrinking a text box (or leader) with text fields, the displayed text is the %text field% instead of the text - RH-43510 and RH-44247)
As Wim says, for us its about the title blocks. when youāre producing a load of layout tabs with title blocks in each ones, it would be a boon to our workflow to be able to insert pre-formatted text boxes into the title blocks in the template file.
Donāt worry about that answerā¦
Apparently that was a respons to a completely unrelated question in a āMakeMusicā forum in 2016.
The same user posted another copy of some unrelated question on DIVA and Iāve now deleted the user.
Sorry, Iām not sure exactly what you mean, but for our title block it would be great to just be able to click in the pre set text box and start typing. Perhaps when creating the box I could specify font, text size and margin left, right or centre.
Hi John - thanks - the concept of text fields came up as possibly related to this (the thing in Text where you can have the text reflect some file or object property by asking for āfXā, this thing:
but it sounds like that is not part of what you need, which greatly simplifies thingsā¦
