i want to buy 2700x
because it 8core cpu and cheaper than any other 8core cpus in korea
so Is 2700x enough to use rhino?
you should make one post where your new build can be discussed.
I’m using a 2700X at the moment. I’m very happy with it and it has a very good value. Make sure you buy a decent mainboard for it. The good thing about the AM4 plattform is that you can later put a Ryzen3000 series CPU in. Later this year Ryzen4000 series CPUs will be released and even those you can upgrade to later. Very good upgrade path.
A 3600X is a good alternative. A little less cores, but increased IPC and runs cooler.
ALso make sure to get a decent cpu-cooler. Also RAM, at least 3200Mhz.
